Hi everyone,
I have many TV-series's (which means a lot of space) and subtitle files for them (srt format), I need to hardsub/embed subtitles in these files and have a standard file size for episodes: around 100 MB for each. What would be the best codec for compression? I want these episodes to be playable online on sites like megavideo.com
I tried many codecs but the quality comes out to be so bad.
What is the best software to use to embed subtitles and output files in that size with best quality?
I tried VirtualDub (DivX 6.8 and Xvid MPEG-4) but the first came out with very large file (500 MB) and the second produced bad quality file.
I also tried Total Video Convector but quality isn't satisfying. Do you have better ideas that you tried yourself?
[SOLVED] I used Total Video Convector to convert to WMV with size around 100 MB for each 45 minutes
Coz knowledge is everything... left ;)
http://mriddler.blogspot.com -
Easiest -> https://forum.videohelp.com/topic316471.html and convert to avi xvid/divx.
If you want a bit better quality try convert to h264/x264 mp4, convert using xvid4psp, open video, open subtitle, choose profile mp4, video->x264, audio->aac. See https://forum.videohelp.com/topic360276.html
BUT I doubt that you are allowed to upload COMPLETE tvseries to sites....maybe if they are your own tv-series...
thanx Baldrick I'll try now....Originally Posted by Baldrick
Frankly, it won't be uploaded.. but after I'm done with converting. I want to be sure that Files will be playable easily......Coz knowledge is everything... left ;)
this one:
gave me so bad quality, even worse than Total Video Convertor!!Coz knowledge is everything... left ;)
Is there any way to reduce the size of subtitle fonts on an existing DVD?
By DeathStalker77 in forum SubtitleReplies: 4Last Post: 25th Jul 2011, 17:35 -
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 15:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 10:18 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56 -
Embed subtitle file into mpeg2?
By bits in forum SubtitleReplies: 7Last Post: 27th Dec 2008, 00:41
